Clutch Whining Wuring Noise
skippy1234
My lads rev 80 developed a whurring whining noise from the clutch along with a shrill type squealing sound that got worse under load or higher revs, taking the clutch casing off I found small metal filings at the bottom of the casing, it turned out to be the clutch/gear drive cogs were worn so I replaced them, problem solved. this may not be the problem with yours but worth checking maybe.
