trialerboy Posted May 28, 2010 Report Share Posted May 28, 2010 Hi all, I have been the owner of a set of Hebo Tech Evo 2 trials boots now for just over six months. However in this short amount of time i have had any problems with them. Within at least six weeks of buying the boots the bottom buckle had came unscrewed ad fallen off leaving me with out the whole bottom strap. My other problem is all the outside layer which i presume is leather is breaking up into scale like bits giving the boots a horrible appearance. I am not sure why this has happened as i have taken good care of the boots and washed them after every use and kept them in my room away from the elements. I have one slight problem which is i brought the boots from carlisle world round so did not purchase it from "instore." Thanks for your time. AA Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted May 28, 2010 Report Share Posted May 28, 2010 What oil are you using to feed the leather? Quote Link to comment Share on other sites More sharing options...
tt5th Posted May 28, 2010 Report Share Posted May 28, 2010 Within at least six weeks of buying the boots the bottom buckle had came unscrewed ad fallen off leaving me with out the whole bottom strap. My other problem is all the outside layer which i presume is leather is breaking up into scale like bits giving the boots a horrible appearance. Firstly you need to get in touch with Hebo to get a replacement strap. It should probably have been tighter from the off but hey, these things happen. I have to remember to tighten up my Gaerne buckles every once in a while just to be on the safe side. If the top layer of the boot is starting to 'flake' off it's not leather, it's Lorica. Not a lot you can do about this unfortunately, this is what Lorica does. Its a tough material so it's only cosmetic. Keep it treated with a good boot wax and it'll last for years. Quote Link to comment Share on other sites More sharing options...
trialerboy Posted May 28, 2010 Author Report Share Posted May 28, 2010 What oil are you using to feed the leather? Im not sure if it is leather or the oher stuff mentioned below. But i dont use oil as i like to have a ridgid boot instead of softer one. Quote Link to comment Share on other sites More sharing options...
captainslackdabber Posted May 31, 2010 Report Share Posted May 31, 2010 The problem with regular washing is that you will remove any oil in the leather. Unfortunately it sounds like yours have already been damaged by this process. You could try reclaiming them with some leather grease from Heine Gericke (motorcycle clothing specialist), and apply liberally. Leave it to soak in over the course of a few days and repeat applications if it looks like it's doing the job. This treatment will make the boots a bit softer, but they will protect you better since a shagged boot is more likely to tear in an impact. I use this stuff on my Stone 3's and all my road gear, leathers boots and gloves and it is top notch. Hope this helps. Paul. Quote Link to comment Share on other sites More sharing options...
smallboy Posted August 10, 2010 Report Share Posted August 10, 2010 Hi I had the same problem after 6 rides on both boots,importers were not interested said normal wear and tear,i bought a pair of sidi boots and are superb and still as new today. Quote Link to comment Share on other sites More sharing options...
corty Posted September 13, 2010 Report Share Posted September 13, 2010 i bought a set of hebo boots and rode with them 3 times they look completely knackered all the outer has cracked and has peeled away what an appaling boot always washed with mild soap and waxed after drying but they are still poor quality even tho i have tried to lok after them , they also leak like a sieve will bin these and avoid hebo in the future not impressed at all! Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted September 13, 2010 Report Share Posted September 13, 2010 I bought a 2nd hand pair of forma grippa, for Quote Link to comment Share on other sites More sharing options...
