Sherco 320 4t Decompresser...
mikee
Has anyone taken the auto decompresser off there 08 320 4t....????
Now i lernt to start the bike i can't rellay see a lot of point in have it on the bike and it makes a lot of noise....
I've got a top end gasket set and i'll be checking the sims soon, so if the decompresser is not needed and easly removed with know ill
efects then i will remove...
Cheers mike
So why do you think the decompressor was added? Most manufacturers try to avoid adding parts that are not necessary - both to save cost and to eliminate potential problems. Was it added just to help old guys like me kick the bike over?
yep thats why decompressers are used, and to make life easier for kickstarts, shafts and so on
but if you start your bike like you should there are no problems, if you start jumping on the kickstart then it will not last long
best regards bob
I think them things are a rather novel little device! You can actually prod that big bore 4t through with a slow gentile methodical prod and it will light off!
The proper ritual for those motors without can be a bit of a drill, yet does still work! Has for ages anyway!
I was a bit surprized a few weeks ago to find one in a large single cyl lawntractor motor of about 19HP! Seems it gave the little electric starter some relief! :rotfl:
