Where Should I Stick My Inline Fuel Filter On My 4rt?
mark1984
Yes. I'd normally put one just after the fuel tap.
The 4RT does not have a fuel tap!!
From the tank the fuel goes through the fuel pump which is fitted underneath the fuel tank. This has a very fine filter system on it as the pump can soon damage if any c**p gets in there :) so the fuel leaving the pump to go to the ECU is very clean :rotfl:
Hence there is no reason to put an in-line filter on the 4RT, just make sure it is clean going in the top of the fuel tank.
