cabby Posted June 14, 2010 Report Share Posted June 14, 2010 Hey folks, looking for some tips in what to look out for when buying a gas gas 125. There is one in my local area, and although I'ev had a look at it, it looks a bit tired with broken mudgards, tyres all worn, leaking for seal, c&s needing replaced. So any help would be good. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
kevhenson Posted June 14, 2010 Report Share Posted June 14, 2010 looks like you found a lot of them lol... check linkage bearings for play, along with wheel bearings, unusual rattles, a lot of gassers rattle but pull the clutch in and it should disappear, check the colour of oil as if its running on atf it should be bright red, if it looks a milky pink colour it will be the waterpump seal gone... all little things but they add up! also check the clutch feels light on the pull the plates can swell making it feel heavy, will require a new clutch pack or metal plates to get it back in spec.. should give you a start and im sure someone will add to it :-) Quote Link to comment Share on other sites More sharing options...
