monkey8414 Posted June 14, 2010 Report Share Posted June 14, 2010 hi all, hopein someone can help, i have been trying to bleed the clutch on my mate's gasgas 350 this evening and once we think we have got all the air out the lever goes solid until i released the bleed nipple. he has fitted a new clutch pack, any ideas wat the prob could be?? dont really wanna drain the oil again if we dont have too thanks in advance Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 15, 2010 Report Share Posted June 15, 2010 First you should be pushing up from the bleeder. Second the clutch outer hub only goes back exactly as it came apart. It is marked ,but odd as most clutches go back together any which way. Quote Link to comment Share on other sites More sharing options...
