Handguards Installed And A Few Other Mods
flypigs
It didn't take long to realize that we needed handguards for the 16. Our four year old was riding just outside of the homerun fence at a baseball field, and all I could think about was his hand hitting one of the fence posts. I found the Moose "mini" aluminum guards for $35 shipped, that are made for 1 1/8" fatbars. As expected, they took a lot of persuading to get them to mount up: A fair bit of bending in a vise w/ a big adjustable wrench, I had to add some electrical tape to the bar-end inserts, cutting off about 3" from each guard and drilling a new hole for the bar-clamp mount, and adding a segment of old inner tube to the bar clamps so they will resist sliding from the fat part of the bar to the thin part.
I couldn't stand the clang-clang of the chain against the chain guard, so I dremmeled out the horizontal surface of the guard where the loosest part of the chain flaps around. I know that I could run the chain tighter since the CS sprocket moves with the swingarm, but I just can't bring myself to have a tight chain. The guard still prevents a finger or foot from getting pulled between the chain and sprocket, but a shoelace might find a way in.
Finally, since the Owen only weighs 42 pounds, we got a 400lb shock spring from Oset. While swapping springs, we found that the swingarm bolts were overtorqued and had a lot of friction. With the new spring and re-torqued swingarm bolts, he now uses the full range of travel, and we will probably switch back to the stock spring fairly soon.
Pete
Edited by flypigs
When i did a few enduro races, quite a few people warned me off those type of handguards as there had been a few broken arms caused by hands slipping off the grips & going through the gap in a crash.
Sounds nasty, just something to bear in mind.
Edited by t-shock 250
Having read your post earlier today, I've just been out to the garage and found that my swinging arm was also far too tight. I removed the lower shock bolt and the arm stayed in exactly the same position, I'm sure my daughter could have ridden the bike in a trial without the shock fitted.
I've slackend the bolts off and refitted the shock and it works correctly now. She's only ridden the bike twice but I'm amazed that I didn't spot the absence of rear suspension. ^_^
Top tip, thankyou
Pete
