bulltaco Posted June 21, 2010 Report Share Posted June 21, 2010 Hi, The two small screws holding the plastic chain guard (2003 290 Sherco) have stripped the threads in the swinging arm. Any ideas for the easiest fix?. I was thinking maybe pop rivets would do temporarily, but they might wear down very quickly. It looks very small and thin for helicoils. Quote Link to comment Share on other sites More sharing options...
gii Posted June 21, 2010 Report Share Posted June 21, 2010 The nicest repair would be the installation of a pair of rivet nuts Quote Link to comment Share on other sites More sharing options...
hrcmonty Posted June 21, 2010 Report Share Posted June 21, 2010 Heli coil it. If you have the ability and gear to do it, then do that. Or if you have a tap and Die set, just run the correct size Tap down it and try save some of it. Quote Link to comment Share on other sites More sharing options...
zippy Posted June 21, 2010 Report Share Posted June 21, 2010 Or drill and tap to the next size screw. There is plenty of swingarm there, so a little bigger hole won't make much difference. Quote Link to comment Share on other sites More sharing options...
ham2 Posted June 22, 2010 Report Share Posted June 22, 2010 Or drill and tap to the next size screw. There is plenty of swingarm there, so a little bigger hole won't make much difference. 'Aint that real close to a stress point? Quote Link to comment Share on other sites More sharing options...
bulltaco Posted June 22, 2010 Author Report Share Posted June 22, 2010 Thanks for replies. I have some rivnuts but they seem to need a pretty big hole, and the shoulder would raise the chain pad/guard a bit high I think. M5 helicoils methinks. If i make an a*** of it I can fill the holes with weld and start again!. Quote Link to comment Share on other sites More sharing options...
zippy Posted June 22, 2010 Report Share Posted June 22, 2010 'Aint that real close to a stress point? It's a Sherco Not a GasGas, so the swingarm ain't gonna snap in half. There is already a hole there and in my opinion going 1 size larger in screw would not cause a problem, any more than that might cause issue. Quote Link to comment Share on other sites More sharing options...
bulltaco Posted June 28, 2010 Author Report Share Posted June 28, 2010 M5 helicoils are fine, the alloy thickness is more than I had thought. Thanks for replies. Quote Link to comment Share on other sites More sharing options...
bulltaco Posted July 1, 2010 Author Report Share Posted July 1, 2010 (edited) PS. I came across a reference to these on the BSA A10 forum. They look spot on for many applications, They're like rivnuts but without the protruding shoulders. http://www.timesert.com/html/install.html#A Edited July 1, 2010 by bulltaco Quote Link to comment Share on other sites More sharing options...
