masso Posted June 21, 2010 Report Share Posted June 21, 2010 hey, gang..what oil do I use for clutch? is it same as hydraulic brakes?....or different oil ?....Thanks masso Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted June 21, 2010 Report Share Posted June 21, 2010 Do you mean clutch/gearbox oil or hydraulic clutch fluid? Quote Link to comment Share on other sites More sharing options...
masso Posted June 22, 2010 Author Report Share Posted June 22, 2010 t-shock 250 said: Do you mean clutch/gearbox oil or hydraulic clutch fluid? .........................the hydraulic.clutch oil...put in master cylinder mine has turned pink ...sounds like moisture in there to me ...Thanks.. massso Quote Link to comment Share on other sites More sharing options...
