stushine Posted June 23, 2010 Report Share Posted June 23, 2010 how do you remove the wheel bearings from the rear wheel? there dosent seem to be anywhere to get anything in, theres a metal sleve/tube behind the bearings? so you can tap them out from each end? Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted June 23, 2010 Report Share Posted June 23, 2010 tap the centre bush to one side.i dont know your model but make sure there is no circlips on some bikes.heat is your best friend taking old ones out and putting new ones in,warm hub with blow lamp Quote Link to comment Share on other sites More sharing options...
stushine Posted June 23, 2010 Author Report Share Posted June 23, 2010 ah ok, its a 2007, il go aqnd have a look Quote Link to comment Share on other sites More sharing options...
des Posted June 23, 2010 Report Share Posted June 23, 2010 use a penny in the center of the bearing knocking it through, it will force the tubbe out and bearing with no damage, i thank you Quote Link to comment Share on other sites More sharing options...
stushine Posted June 23, 2010 Author Report Share Posted June 23, 2010 use a penny in the center of the bearing knocking it through, it will force the tubbe out and bearing with no damage, i thank you so that tube/bush comes out? Quote Link to comment Share on other sites More sharing options...
stushine Posted June 23, 2010 Author Report Share Posted June 23, 2010 sorted cheers Quote Link to comment Share on other sites More sharing options...
