gasgas694 Posted June 24, 2010 Report Share Posted June 24, 2010 I have just brought a 2005 gas gas 250cc so my knowledge of engine's is rubish the problem i have is doing a oil change i know where you drain the old oil and i know where you top the oil up i just dont know how much oil to put in or where the dipstick is??? Quote Link to comment Share on other sites More sharing options...
pandelboy Posted June 24, 2010 Report Share Posted June 24, 2010 loads of info on this in the forums mate, but here goes for you. 400cc or 400 ml of atf dexron iid, or light gear oil . once you have put the oil in then with the bike stood upright if you look in the sight glass on the clutch cover, it should be about 3/4 of the way up the sight glass. Quote Link to comment Share on other sites More sharing options...
motomerlin Posted June 24, 2010 Report Share Posted June 24, 2010 I tend to use 450cc. ATF is fine. No dipstick, use the sight glass. Quote Link to comment Share on other sites More sharing options...
