kev99 Posted June 24, 2010 Report Share Posted June 24, 2010 hi all, just a quick question i have just bought a pro 280 does anyone have a prefrence on quick or slow action throtle i think mine is quick and while i am only learning to trail seams a bit too much any help please Thanks kev Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 24, 2010 Report Share Posted June 24, 2010 If this is a brand new bike I'm pleased to tell you it will calm down over time but a slow throttle isn't a bad idea anyway if your just starting out. It doesn't make a lot of difference other than just off the bottom. It's better for controlling the bike when your riding up a section at say a slow jogging pace. The bike won't jump forward so much and feel like it wants to take off. On the other hand when you want that urge its still there with a little more twist. I'd recommend giving it a try, they aren't very expensive and you can always go back. Quote Link to comment Share on other sites More sharing options...
kev99 Posted June 24, 2010 Author Report Share Posted June 24, 2010 Thanks bigfoot the bike is not new i think its 03 but had virtualy no use will try the slow throtle as it just wants to rear up also riding slowly with no clutch its a bit frantic like its an on off switch instead of a throtle cheers for help kev Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted June 24, 2010 Report Share Posted June 24, 2010 You bought a gas gas pro 280 to learn on........... There's your problem right there. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted June 24, 2010 Report Share Posted June 24, 2010 If you have a Domino throttle and the throttle tube is white then its a quick one. If you already have the black (slow) throttle tube you may want to look at other means of 'softening' the motor such as a head spacer or flywheel weight, if not already installed. Quote Link to comment Share on other sites More sharing options...
gizgrey Posted June 24, 2010 Report Share Posted June 24, 2010 If you have a Domino throttle and the throttle tube is white then its a quick one. If you already have the black (slow) throttle tube you may want to look at other means of 'softening' the motor such as a head spacer or flywheel weight, if not already installed. i have a 280 pro aswell and am starting off,i had a slow throttle until i smashed it off a tree,my mate said he had a slow throttle in his shed(white)i noticed a hell of a diffrence with it,probably because its a fast one...it seems to wheelie up everything with very little effert,this will explain why.. Quote Link to comment Share on other sites More sharing options...
