smelling123 Posted June 25, 2010 Report Share Posted June 25, 2010 Hi, Just rebuilding a 247 Cota motor and the big end is a plain (bronze) bush. Ive never ever seen this on a 2 stroke engine. I have a new rod kit so I'll put that in, but I wondered if anyone had ever seen a Monty with a plain bush big end....seems strange, maybe the previous owner was trying to save costs or maybe Montesa did this at some stage - anyone know?? I can see how a bushed small end would be OK, as the movement is only through a small range (maybe 20 degrees per revolution) but the big end moves through 360 degrees. Having said that plenty of 4 strokes use shell type bush big ends - but are oil fed... Any comments anyone? many thanks Stu Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 25, 2010 Report Share Posted June 25, 2010 I will bet that it didn't run with a plain big end for long Quote Link to comment Share on other sites More sharing options...
sdm Posted June 26, 2010 Report Share Posted June 26, 2010 What year or engine number is it? Quote Link to comment Share on other sites More sharing options...
smelling123 Posted June 28, 2010 Author Report Share Posted June 28, 2010 Its a 21M. Im cant believe is isnt a bearing - sure someone was trying to save some cash - so Im going to put the rod kit I have in. It has run but looks recently rebuilt (but I never trust that..), so its a new rod. thanks all. Quote Link to comment Share on other sites More sharing options...
