Rear Brake Fluid Resevoir 2003 280 Pro
stevie78
Hi there can anyone tell me where this is ment to fix to as mine is cable tied to the frame .
cheers stevie :mellow:
My 02 Pro had the reservoir attached up by the airbox intake, much like the older models and I made a bracket to move it down under the tank like the newer Pros. It's easier to see and service. There is a spring clip that the reservoir bolts to that attaches to the cylinder brace in the newer bikes, if you look at a newer bike you'll see how they go and your GG dealer should be able to get one for you, I doubt they cost much.
Jon
