pudrev3 Posted June 28, 2010 Report Share Posted June 28, 2010 hey guys,please help, i have 2 problems,the first one ive said in the title and the second one is , when the revs are low and you gas it quick ,it sounds like there is not enough juice getting to it,but ive cleaned the carb i think,although i dont really know what i,m doing, can anybody help me please, oh its a rev 3 04 model,cheers chris Quote Link to comment Share on other sites More sharing options...
stork955 Posted June 28, 2010 Report Share Posted June 28, 2010 Gday, it sounds like you have an airleak in the inlet manifold somewhere. Have a good look around that area first. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
tonybroad Posted June 28, 2010 Report Share Posted June 28, 2010 and check your throttle slide needle is retained properly Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted June 28, 2010 Author Report Share Posted June 28, 2010 that would\ make sense matey , it is blowing a bit at the front, i knew it was a good idea this site,cheers bud Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted June 28, 2010 Author Report Share Posted June 28, 2010 i have allways had problems with my carb, if i lean it over in any direction ,petrol comes out the 2 breather pipes on the carb, ive tried cleaning it ,but dont really know how to properly, i have a feeling it is blocked or something:) Quote Link to comment Share on other sites More sharing options...
grahamjayzee Posted June 29, 2010 Report Share Posted June 29, 2010 i have allways had problems with my carb, if i lean it over in any direction ,petrol comes out the 2 breather pipes on the carb, ive tried cleaning it ,but dont really know how to properly, i have a feeling it is blocked or something:) The trait you describe is a factory addition. It's there in case the 'Beta' badges come off. That way it's still clearly identifiable as a Beta! If you search the Beta forum on 'leaking carbs' you'll find that you're not alone on this one. The same was the case on my 1992 Beta Zero 260. The only problem it caused me was that the missus banned me from keeping it in the lounge as the smell of petrol gave her a headache... Graham Quote Link to comment Share on other sites More sharing options...
chewy Posted June 29, 2010 Report Share Posted June 29, 2010 The trait you describe is a factory addition. It's there in case the 'Beta' badges come off. That way it's still clearly identifiable as a Beta!If you search the Beta forum on 'leaking carbs' you'll find that you're not alone on this one. The same was the case on my 1992 Beta Zero 260. The only problem it caused me was that the missus banned me from keeping it in the lounge as the smell of petrol gave her a headache... Graham Nice one Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted June 29, 2010 Author Report Share Posted June 29, 2010 haha quality matey, Quote Link to comment Share on other sites More sharing options...
rev3 Posted June 29, 2010 Report Share Posted June 29, 2010 If the carb is not the problem it could be the main seals are leaking, used to be common many years ago, although i must admit i have not seen it recently. Maybe the quality (including Beta) has improved. Quote Link to comment Share on other sites More sharing options...
