Gearbox Level
colly
i no the correct amount is 450ml but it's quite a pain to not know how much oil you have in, like on the beta's there was window to view the level, for all i know mine could be well down, with out knowing, so how often do you keep checking yours? it would of been ok, if the limit was the filler on the crank case. but it's not....... :) thanks colly........... :(
  • 4 weeks later...
  • 2 weeks later...
Guest Ady Witting
You need to change the about every 6 months because the selectar drum runs next to the oil drain so it will get all muck in it. So you need to change it every 6 months.
Guest Ady Witting
After washing it of DO NOT START THE BIKE UP as the air box is proon for getting water in so clean it out. If you don't clean the water out the water will go into the engine and will effect the main bearings and componts.
I have just changed my second hand Sherco main bearings at a cost of around
First sensible thing you've said. If unjustified. Firstly potable water shouldn't do any damage to bearings if flushed fairly soon after washing, secondly, best way to flush (small quantities) of water is to start the bike. Do not try this with saline water. It nearly put me hospital.
For more info regarding Sherco waterproofing see previous posts by Ishy.
BTW IMO, never use power washers.
Remember oil is cheap, gearboxes are not. Change it as often as possible.
Edited by TooFastTim
