steve1979 Posted July 3, 2010 Report Share Posted July 3, 2010 What a day, way out riding in the middle of nowhere, literally. Over huge hills, through marshy bogs etc when the bike conked out in the middle of nowhere about as far from civilization as possible in Shetland. Engine just died and refused to start (stator problems) i think and to top it off with all the kicking on the kick starter the bugger snapped off and took a big chunk out of my carbon lookalike frame protector at the same time, BIG BOO eventually got the bike bump started just as it started to rain. What a day. Still no point in getting mad about it lol Quote Link to comment Share on other sites More sharing options...
richt Posted July 3, 2010 Report Share Posted July 3, 2010 What model do you have and which part of it sheared? unfortunately you may get mad about it when find out how much the parts cost! Quote Link to comment Share on other sites More sharing options...
steve1979 Posted July 3, 2010 Author Report Share Posted July 3, 2010 Hey Rich T, ha ha yes there not cheap, how ever i am ! lol no seriously for the short term i may get it welded until i can get a new one ordered, i think they retail around the Quote Link to comment Share on other sites More sharing options...
wri5hty Posted July 3, 2010 Report Share Posted July 3, 2010 Quote Link to comment Share on other sites More sharing options...
richt Posted July 4, 2010 Report Share Posted July 4, 2010 Steve1979, You are a calm chap! There are parts catalogues to download on 'trialspartsusa' or have a look at 'haventrialsport' they list everything with prices. The arm is only available as a complete assembly but the other parts are available individually! Why? You can weld it till you get another then keep it as a spare. I have seen a few break off and its usually when the arm has turned out and the bike falls on that side and the rider went some where else. Quote Link to comment Share on other sites More sharing options...
jse Posted July 4, 2010 Report Share Posted July 4, 2010 I have seen a few break off and its usually when the arm has turned out and the bike falls on that side and the rider went some where else. I've also seen a couple of them snap when the capscrew through the bushing is allowed to get loose. That over-stresses the lower part of the lever by spreading the machined tabs on the bottom of the lever that pivot on the bushing. I always advise Loctite on the capscrew and use a little lube on the bushing/tab area now and then. Jon Quote Link to comment Share on other sites More sharing options...
steve1979 Posted July 8, 2010 Author Report Share Posted July 8, 2010 Thanks guy's, that's excactly what happened the top cap had come off i think as it was missing, and it's broken where you described. Probably my fault as i took it apart a while ago to replace one of the o rings and lube it all up. so it's probably worked it's self loose Quote Link to comment Share on other sites More sharing options...
