98 Easy Electrical Problem
theom
Just had the stator rewound on my 98 scorpa easy, the bike is fine at low revs and in first gear etc, put under load the bike doesnt want to rev out. A mate of mine said that this sounds like something is giving way in the electrics, anyone got any ideas? Just had the stator rewound so can rule that out. Cheers.
Gday, its possible that the coil may be failing, although it will pay to have a good look around other stuff first. What colour is the spark plug? Air cleaner OK etc. All wiring OK, no corrosion in connectors etc. Check those things out as they are the easiest.
Cheers,
Stork
Thanks for the reply, think it may be the wiring/cdi that has failed any idea where i could get a new/used set of these from? thanks.
Edited by theom
