jonnyhart Posted July 4, 2010 Report Share Posted July 4, 2010 I have a 2004 250cc pro and all of the exhaust silencer mounts have snapped off the mid box, is there a way of repairing it or does it have to be a replacement? Cheers Quote Link to comment Share on other sites More sharing options...
jam Posted July 4, 2010 Report Share Posted July 4, 2010 You will need to remove the whole unit and find someone who can ally weld, it can be done. Good Luck Quote Link to comment Share on other sites More sharing options...
jonnyhart Posted July 4, 2010 Author Report Share Posted July 4, 2010 You will need to remove the whole unit and find someone who can ally weld, it can be done.Good Luck Is it possible to weld the complete silencer to the mid box, instead of using the mounts? Cheers Quote Link to comment Share on other sites More sharing options...
mik60ish Posted July 4, 2010 Report Share Posted July 4, 2010 I've just just had my 05 TXT 250 Pro repaired took it to my welder decided to fabricate new bracket and cut the old one of as you couldn't weld on to a weld if you see what I mean, and the metal goes brittle after a re-weld. Its a fault with the design in my opinion always having to have it welded on the different stress points. I have 07 125 and the box is different to my 05 the middle box its all one piece. So either weld it yourself or someone that can weld alloy! Quote Link to comment Share on other sites More sharing options...
jonnyhart Posted July 4, 2010 Author Report Share Posted July 4, 2010 Could my silencer be welded to the mid box to make it all one piece instead of making new brackets? Cheers Quote Link to comment Share on other sites More sharing options...
baldilocks Posted July 4, 2010 Report Share Posted July 4, 2010 Could my silencer be welded to the mid box to make it all one piece instead of making new brackets? Cheers it could be done but its not the best idea. you silencer will have rubber orings in the joint between silencer and mid box. If you weld it on you wont ever be able to change them again. Quote Link to comment Share on other sites More sharing options...
