neil king Posted July 9, 2010 Report Share Posted July 9, 2010 (edited) Just picked up an '84 300. It starts pretty good, but won't run clean until the carb is almost dry. It runs good for about 10 seconds before it runs out of gas and dies. I thought maybe the float valve is leaking or floats too high but it looks like it would start running better before the carb is practically empty. It's got the stock carb, 45 pilot, needle in the lowest position. I didn't check the main jet size, but I'm no where close to needing that yet. Edited July 9, 2010 by Neil King Quote Link to comment Share on other sites More sharing options...
technowaldo Posted July 9, 2010 Report Share Posted July 9, 2010 sounds like it might be running way too rich especially if it starts to run fine when its running dry on fuel is ur air filter clean ? Quote Link to comment Share on other sites More sharing options...
neil king Posted July 9, 2010 Author Report Share Posted July 9, 2010 I had to choke it to start it after running it dry. I didn't have the filter hooked up. Quote Link to comment Share on other sites More sharing options...
neil king Posted July 9, 2010 Author Report Share Posted July 9, 2010 Yes it's running rich, I know that much. Quote Link to comment Share on other sites More sharing options...
htrdoug Posted July 10, 2010 Report Share Posted July 10, 2010 Make sure you clean out all passages in the carb completely,but I bet it's the float,A new float is only about twenty bucks ,Call Herdan Corp or go to Dellorto direct,best solution is a OKO,but I wait until you get the other stuff on the old bike sorted before spending the dough on an OKO(saw your post on ADVRider) but when you start getting her working good you definately want the OKO. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted July 10, 2010 Report Share Posted July 10, 2010 Make sure you clean out all passages in the carb completely,but I bet it's the float,A new float is only about twenty bucks ,Call Herdan Corp or go to Dellorto direct,best solution is a OKO,but I wait until you get the other stuff on the old bike sorted before spending the dough on an OKO(saw your post on ADVRider) but when you start getting her working good you definately want the OKO. DITTO !!!! Quote Link to comment Share on other sites More sharing options...
neil king Posted July 18, 2010 Author Report Share Posted July 18, 2010 I think I'm gonna let someone else deal with it. While I think it can be fixed up, there is nothing about the bike that I really like, though it would be neat if I could get a TL250 motor in it. I have a TL250 that needs more than the Fantic. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted July 18, 2010 Report Share Posted July 18, 2010 Pm me about the 300 ... I may have a home for it ... Quote Link to comment Share on other sites More sharing options...
neil king Posted July 18, 2010 Author Report Share Posted July 18, 2010 It's spoken for already. I had him in mind when I bought it, thinking he would want it if I didn't. Sure enough I got a email from him when he found out I had it. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted July 19, 2010 Report Share Posted July 19, 2010 As long as it gets a good home .... Quote Link to comment Share on other sites More sharing options...
