A Few Missimg
:P
Hello boys and girls.
Thanks for all of the e-mails letting me know were to find you.
I thought I was in a strange place when I logged on. I was and it was nice. Good work Andy.
I have been busy working on "Viggen" A Viggen what the hell is a Viggen.
A four stroke fuel injected trlals bike.
Think of this
250 Four stroke
Mikuni partial fuel injection
Showa front and back suspension.
User programable ignition (on the fly)
Rear fender attached to the swing arm (for greater clearance)
Foot pegs that rotate slightly for better balance.
No sub frame
Replacable carbon fiber boot guard areas.
Disc brakes that are inside the spokes attached to the hub.
A single sided swing arm
Gas inside the frame.
Run flat tires
A heads up (HUD display inside the helmet) tach to tell the rider when to shift gears for better usage of torque range.
A weight of 120 Ibls
Four gears with the fourth one changable by the owner
An electronic reverse gear switchable on the fly in a section.
A memory chip for remembering what your score was in each section and what gear and rpm range that you rode it in.
And lots more goodies that are in the works. :madsanta:
All the best
Mad BillyT
