bennett Posted July 18, 2010 Report Share Posted July 18, 2010 (edited) Hi , Bought an 01 beta a few months ago. When cleaning last week noticed that the gear oil window looked white! dropped gear oil and its like yogert. Been told its proberly the water pump seal?? or the caseing?? is this an easy job??? also the carb is leaking fuel out of the side, is there a seal you can buy for them??? cheers graham Edited July 18, 2010 by Bennett Quote Link to comment Share on other sites More sharing options...
mark1984 Posted July 18, 2010 Report Share Posted July 18, 2010 There are many reasons that water could be getting in to your gear oil if the oil is not getting out though it is most probably getting in from the top somewhere on a vent pipe or it could be the water pump seal if you have a good mechanical knowledge it should not be too hard to fix you should buy the seals that you think it is and then just start hunting. Quote Link to comment Share on other sites More sharing options...
scraggydog64 Posted July 18, 2010 Report Share Posted July 18, 2010 Not that hard a job. The magnesium clutch / water pump case does not like anti freeze and water and corrodes, you need to use a proper engine coolant. I would not discount the seals but if you remove the water pump cover it is likely you will see the corrosion. I think the new casings are alloy and not magnesium. Me and my lad both used to ride REV 3s and our casings went within weeks of each other. Then he hit his off a rock. I bought three in a matter of months. BETA bits are quite pricey now down to the Quote Link to comment Share on other sites More sharing options...
luct4 Posted July 19, 2010 Report Share Posted July 19, 2010 Hello look at my topic (clutch cover changing) and you will find the whole description to change te clutch cover. I done it forr the first time and it's verry easy. time +/- 2 hours. I only need to putt new coolant on the bike and asked on the forum what to refill so it would not corrodate the cover again. What do you need: -clutch cover case -new oil seals (gear shift, kick starter, water pump (inner) -clutch cover seal -to replace the bearings off the water pump haet the cover with an airheather and putt some grease at the bearings I also ordered a new pump fann and te sealing off the pump cover Greathings Luc (the belgium Beta rider) Quote Link to comment Share on other sites More sharing options...
luct4 Posted July 19, 2010 Report Share Posted July 19, 2010 Hello i forgot to tell you +/- the price (in euro) 94 Quote Link to comment Share on other sites More sharing options...
bennett Posted July 20, 2010 Author Report Share Posted July 20, 2010 Thanks for the replys! Picking new seals up tomorrow so gunna strip it down first thing. Dont even know if the caseing is leaking, just hopeing its the water pump seal makeing the oil go mulsifide! FINGERS CROSSED Quote Link to comment Share on other sites More sharing options...
rokhopr Posted July 24, 2010 Report Share Posted July 24, 2010 I only need to putt new coolant on the bike and asked on the forum what to refill so it would not corrodate the cover again. I use Silkolene Pro Cool Coolant - no issues with corrosion Quote Link to comment Share on other sites More sharing options...
