luct4 Posted July 27, 2010 Report Share Posted July 27, 2010 Hello does some one have a torque tension scedule for the bolts off my Beta ReV 3 250cc - 2007? Greathings Luc (the belgium rider) Quote Link to comment Share on other sites More sharing options...
chris morris Posted July 27, 2010 Report Share Posted July 27, 2010 had a file with these in, think i may have copied it from a previous post Tightening torque Rev3: Shock absorber-Swingarm 45Nm Shock absorber-Frame 45Nm Connecting frame rod-frame 23 Nm Cylinder-Crankcase 20-23 Nm Primary drive gear 120 Nm Handlebar 25 Nm Engine-frame 50 Nm Swingarm bolt 90 Nm Front wheel axle 65 Nm Rear wheel axle 65 Nm Steering stern bracket 25 Nm Rear fender bracket 10-15 Nm Front brake pad 20-23 Nm Rear brake pad 20-23 Nm Engine Head-Cylinder nuts 15-16 Nm Front axle fixing nuts 10 Nm Flywheel 140 Nm As for a schedule, if they're loose tighten them. Quote Link to comment Share on other sites More sharing options...
luct4 Posted July 28, 2010 Author Report Share Posted July 28, 2010 Chris thank you for the information. Greathings Luc Quote Link to comment Share on other sites More sharing options...
