oldoffroader Posted July 27, 2010 Report Share Posted July 27, 2010 my mono keeps dying, seems like fuel starvation, after a bit of bouncing(not that i do that sort of riding) but it creates the problem it just dies, kick it over and off it goes again, just replaced float valve which everything pointed to, but still have problem any ideas gratefully accepted Quote Link to comment Share on other sites More sharing options...
jse Posted July 27, 2010 Report Share Posted July 27, 2010 my mono keeps dying, seems like fuel starvation, after a bit of bouncing(not that i do that sort of riding) but it creates the problem it just dies, kick it over and off it goes again, just replaced float valve which everything pointed to, but still have problem any ideas gratefully accepted Are you running a TK or Mikuni carb? Jon Quote Link to comment Share on other sites More sharing options...
oldoffroader Posted July 27, 2010 Author Report Share Posted July 27, 2010 TK Quote Link to comment Share on other sites More sharing options...
jse Posted July 27, 2010 Report Share Posted July 27, 2010 TK I'd make sure the filters up inside the tank are clean (on top of the petcock) and it flows sufficient fuel (sometimes the rubber disk in the valve deteriorates). As you replaced the float valve I'm assuming you checked the float level so that should be o.k. Check the fuel tank cap vent to be sure it allows air into the tank properly. Sometimes a new, properly gapped plug will help. Have you adjusted the carb screw for any changing weather conditions lately? The mixture screw needs to be checked now and then as the weather changes. Jon Quote Link to comment Share on other sites More sharing options...
