Beta Rev3
stephen1967
Sometimes my throttle sticks open and does not return to it`s normal position. If I take off the handlebar grip it is fine,but once . I start to put the grip back on it occasionally sticks. I am sure there is an eas.y solution but it has got me stumped at the moment. Many thanks for your help.
Could be that the cable needs oiling, or perhaps it is starting to frey inside and causing a restriction.
If you remove the cable, make a carefl note of it's route. I tend to take a few snaps with the digital camera, so if I can't work it out when refitting, I just check the picture.
Hope this helps.
Pete
  • 2 weeks later...
  • 2 weeks later...
