supermotodaz Posted July 30, 2010 Report Share Posted July 30, 2010 Im just changing from motul fully to semi synthetic Ipone oil, normally mix 80:1, would i still use the same ratio for a semi oil, i know Sherco and other manufacturers all recommend certain brands of oils for there own reasons and a mix of around 60:1 in the case of Sherco but i assume all manufacturers will always air on the side of caution when it comes to giving advice. Cheer,s Daz Quote Link to comment Share on other sites More sharing options...
shercojay Posted July 30, 2010 Report Share Posted July 30, 2010 i do Quote Link to comment Share on other sites More sharing options...
copemech Posted July 31, 2010 Report Share Posted July 31, 2010 It is still good oil and you can still run it at 80:1 I would not use excess oil in the mix, as it fouls the exhaust! Quote Link to comment Share on other sites More sharing options...
supermotodaz Posted July 31, 2010 Author Report Share Posted July 31, 2010 Thanks for the advice guys, 80:1 it is then. Quote Link to comment Share on other sites More sharing options...
