Rtl Drain-plug Oil Leak.
gaff
Help please, the drain plug no my 87 RTL keeps leaking, casings look fine as does the thread on the bolt, surfacings look clean and un-tarnished as does the rubber gaskit on the inside of the bolt ??? Any ideas !
Any advice would be welcome.
Thanks in advance.
Gaff.
Thanks for the advice guys, i'll try D.Sileo's approach first (just to get me through my 1st trial on an RTL, i'll keep you posted), then look into Ishy's answer when Christmas is over.
Thanks again.
Gaff.
Just to let you know that the bike was okay for the week-end and that the "Plumber Tape" worked a treat with no leak at all. Now all i need to do is sort out a new drain-plug and O'ring when able to.
Thanks again.
Gaff.
