Removing Crank Nut
supermotodaz
Need to do mains on a 2000 290 i just picked up, i,ve undone flywheel nut by holding oposing crankshaft nut but how can i undo this nut, is it only poss with a clutch holding tool or is there another proven method i can use, another question whats the best way to decoke the downpipe, this one,s full of crap, looks like its been ran way to rich.
Cheer,s
Daz
You can't do it with a clutch holding tool, you need to put the flywheel back on and get a flywheel holding tool or buy a impact wrench See Here
To decoke your front pipe set it on fire, works a treat but watch you don't get it to hot and discolour it.
Cheer, for advice i,ll have a go later today.
