Need Sherco Heavy Spring
hammer
I have not seen any. And to be honest, I am not absolutely sure exactly what years will interchange on the springs.(mine is '07, as example) However, I think '08'09'10 and likely the '11 may well use the same.
Now that Nationals are over, this may well be a good project for RYP Brad to investigate, and possibly have a few made up. Seems there is some demand, yet limited.
The MX specialty suspension shops can do it. But would cost a lot for just one! Replicate in a 10-15% heavy range.
Last word I seen stated the TRP would not fit the '10 model untill re-work, not sure if it is out yet, however the Ohlins did still fit.
Splatshop UK had the Ohlins listed at about $600 US, but you wou would need to see if they can get the heavy spring on it as well. They seem good at returning e-mail, so never hurts to ask.
And That is all I know about That! :agreed:
Getting a spring wound is not that bad, do some research on the web. I tried the TRP shock for a 09 and back on the 2010 doesn't fit. Back the cost of a new spring out of the cost of a new TRP and it makes the cost cheaper for a new shock. The TRP is a very nice shock, it just looks sexy all by itself ! I have a heavier spring somewhere, what is the size of your spring ie inside,outside and length ?
