cooper956 Posted August 3, 2010 Report Share Posted August 3, 2010 im a biginer on bikes played with car and tractor engiece ect but not many bikes. iv been playing with my 1996 250 again today fitted new plug ect and intake manifold as old one cracked but still it lacks power and wount idol off choke fine on choke just soots the plug up after a while. questions i have are i removed the covers on the side of the engine as you sit on the bike the left side plastic cover and looked dry with no oil leeking inther (is this the mag side) and the other side (right side as you are sat on the bike) the clutch side and should this be full of oil? a gray oil at that? there is a seal on the caseing so looks like oil might be supost to be there but im just checking. Quote Link to comment Share on other sites More sharing options...
tt5th Posted August 3, 2010 Report Share Posted August 3, 2010 Yep, oil on the clutch side, get some fresh popped in and the dry side is the mag side. The not idling is probably just the carb needing a clean. I'd take it off and clean the jets and that. Quote Link to comment Share on other sites More sharing options...
cooper956 Posted August 3, 2010 Author Report Share Posted August 3, 2010 cleaned the car 3 times 3rd time knoticed the seal of one of the brass jets (the long one) the o ring was damaged replaced this and still the same so given up and doing the folk seals as we speak Quote Link to comment Share on other sites More sharing options...
tt5th Posted August 11, 2010 Report Share Posted August 11, 2010 Any joy getting it running? Has to be something to do with the carb if it'll run on choke. The idle circuit must have a blockage somewhere or the carb is just way out of adjustment. Quote Link to comment Share on other sites More sharing options...
