gas_gas_96 Posted August 5, 2010 Report Share Posted August 5, 2010 hi ive posted previous problems about my bike and you all fixed them so here goes sometimes if i stall the bike because it is still a cold engine i can knock it back into neutral and it will roll freely but a couple of times now it has knocked itself into gear also i rode it the other day and rolled it into the garage for storage when i came back to it it was in gear and nobody had ****ed around with it is this a simple fix or could it be the clutch ? thanks Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted August 5, 2010 Report Share Posted August 5, 2010 (edited) Check out GasGas on you tube.....there's a few vids on maintenance, one of which shows how to re-align the gear selector shaft. Click here Watch from about 6 mins for the transmission set up. Hope this helps ! Edited August 5, 2010 by houseape1000 Quote Link to comment Share on other sites More sharing options...
jse Posted August 6, 2010 Report Share Posted August 6, 2010 hi ive posted previous problems about my bike and you all fixed them so here goes sometimes if i stall the bike because it is still a cold engine i can knock it back into neutral and it will roll freely but a couple of times now it has knocked itself into gear also i rode it the other day and rolled it into the garage for storage when i came back to it it was in gear and nobody had ****ed around with it is this a simple fix or could it be the clutch ? thanks The clutch has nothing to do with the gear selection so I wouldn't worry about that. The 96 is totally unlike the Pro and there is a spring-loaded arm with a roller (under the clutch) that locks the shift drum in gear and neutral (the roller drops into the gaps on a star-shaped collar on the end of the shift drum). Look for a weak spring on the roller arm and/or worn bushings in the arm/roller assembly. The parts can be replaced without splitting the cases. Jon Quote Link to comment Share on other sites More sharing options...
gas_gas_96 Posted August 7, 2010 Author Report Share Posted August 7, 2010 (edited) Check out GasGas on you tube.....there's a few vids on maintenance, one of which shows how to re-align the gear selector shaft.Click here Watch from about 6 mins for the transmission set up. Hope this helps ! hi thanks but my gas ga unfortunately isnt a pro as i only want it to begin on i will be buying a pro at a later stage though thanks anyway jack Edited August 7, 2010 by gas_gas_96 Quote Link to comment Share on other sites More sharing options...
gas_gas_96 Posted August 12, 2010 Author Report Share Posted August 12, 2010 hi thanks jon where do i find all this you are talking about because its quite baffling to me its my first trials bike and im learning . Quote Link to comment Share on other sites More sharing options...
