richt Posted August 5, 2010 Report Share Posted August 5, 2010 (edited) I have scraped the black coating on my Alloy fork tube Has anyone had their's repaired or recoated and if so where and how much? Any help apreciated. Edited August 5, 2010 by RichT Quote Link to comment Share on other sites More sharing options...
richt Posted August 18, 2010 Author Report Share Posted August 18, 2010 I have recently had a quote from 'Bodycote' for retreating this type of fork tube, Quote Link to comment Share on other sites More sharing options...
steve1979 Posted August 18, 2010 Report Share Posted August 18, 2010 Ouch! thats a shocking price, surley there must be a cheaper option out there somewhere. Hope you get a better price elsewhere Quote Link to comment Share on other sites More sharing options...
jse Posted August 19, 2010 Report Share Posted August 19, 2010 Ouch! thats a shocking price, surley there must be a cheaper option out there somewhere. Hope you get a better price elsewhere I'm assuming the scratch is on the travel area of the seal which resulted in a leaking seal. For a non-cosmetic but possibly a functional fix in the meantime you could try filling in the scratch with superglue and the use a piece of 600 grit wet/dry sandpaper on a piece of bar stock (or any piece of smooth machined steel) to carefully sand the scratch smooth so it won't cut the seal lip. Don't sand just on the scratch in one area or you'll have a flat spot but sand in an around-the-tube motion. You won't have the pretty coating on the sanded area but you can turn the tube to move the spot around to the back. Don't over sand, just enough to smooth over the raised ridge on either side of the cut. Jon Quote Link to comment Share on other sites More sharing options...
mark1984 Posted August 19, 2010 Report Share Posted August 19, 2010 try buying just the top part of the shock i know of a company that just got a load of 315 r spares they might have a fork or pidcock will surely be cheaper than 400 for a repair Quote Link to comment Share on other sites More sharing options...
richt Posted August 19, 2010 Author Report Share Posted August 19, 2010 Hi JSE, The the damage was/still is on the travel area, I have lightly smoothed off the ragged edges so it is max diameter and then filled the sratches with Black nail varnish, It matches very well and I have no leaks. The varnish was Quote Link to comment Share on other sites More sharing options...
nzralphy Posted August 19, 2010 Report Share Posted August 19, 2010 If the nail varnish fails try a hard black paint. Quote Link to comment Share on other sites More sharing options...
steve1979 Posted August 19, 2010 Report Share Posted August 19, 2010 If all else fails how about chemical metal, it will sand up good when wet and i assume would be harder wearing than nail varnish, but if nail varnish works, excellent and you have enough left over to become a goth Quote Link to comment Share on other sites More sharing options...
richt Posted August 19, 2010 Author Report Share Posted August 19, 2010 but if nail varnish works, excellent and you have enough left over to become a goth I got some strange looks from the shop assistants, it made me think I should have asked a Goth to go out with so I could borrow some to see if it worked, Quote Link to comment Share on other sites More sharing options...
richt Posted September 28, 2010 Author Report Share Posted September 28, 2010 This seems to be a good fix. 5 weeks later, it looks just the same as when I put it on and no oil leaks Quote Link to comment Share on other sites More sharing options...
