triple_x Posted August 6, 2010 Report Share Posted August 6, 2010 Hi I am rebuilding the above engine for a colleague. Is the gearbox timed in the same way a Sherpa is? For example the Sherpa selector drum is positioned with the cluster in neutral and this is obvious, as the straight side of the diameter with the selection indents is to the rear and set vertical. I am sure I can work it out but it is 31 years since I have had a Cota engina apart and that was a 250 and i always appreciate any tips. Thank you Martin Quote Link to comment Share on other sites More sharing options...
