boofont Posted December 22, 2003 Report Share Posted December 22, 2003 Just wondering what tweeks you have done to the suspension? I'm thinking of adding some pre-load to the rear, my bike tends to sump out a lot. Mind you, I am a fat git so that may have something to do with it? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted December 23, 2003 Report Share Posted December 23, 2003 I would be careful as a pal had the sachs on a shock dyno and out of the 5 (?) settings on damping only 3 made any difference to its function, ie 3 settings gave the same reading.. Quote Link to comment Share on other sites More sharing options...
monty-python Posted December 24, 2003 Report Share Posted December 24, 2003 Boofont , having ridden your scorpa, i suspect that your sumping out cos the front end is too soft, maybe try adjusting that first . I thought the rear suspension was really good ( I'm 14 stone, so no lightweight either). A bit more compression on the front would work wonders. (or a diet ,arf, arf) Quote Link to comment Share on other sites More sharing options...
