nicbrrghs Posted August 7, 2010 Report Share Posted August 7, 2010 The bike started running erratically and lacking any power eventually dieing with no spark at all. I have changed the coil pack and still only sparks intermittently, on pulling the side cover of the left of the bike I noticed a lack of a gasket and that a lot of crap/dirt had got in.l Could this be the cause or does anyone know better? Got one of the lambretta coil packs of ebay on advice from a forum seems okay. I have a yellow wire which isnt connected to anything at the moment. What size flywheel puller do i need i have already got quite a collection but not small enough for this. Thanks in advance for any help or advice. Quote Link to comment Share on other sites More sharing options...
caballero125 Posted August 8, 2010 Report Share Posted August 8, 2010 (edited) I have just had trouble with my rc mag misfire - not revving , but i replaced the wiring from the mag to the cdi with heat resistant cables and also found the external pick up was loose and corroded between the stator AND PICK UP . I tried the bike out last night and what a difference the bloody thing fly, now . I add my 125 has dansi electronic ignition with a solid plastic source coil , but my trials has a wound coil that i read can play up BUT A REWIND SHOULD FIX THE PROBLEM Edited August 8, 2010 by caballero125 Quote Link to comment Share on other sites More sharing options...
