Gasgas
slack
Hi to everyone, I have an 05 Raga 300 which i've owned for a couple of months now.Does any body know the mixture settings as mine is set at 1 turn out with a nice colour to the plug,but it seems to pink alot when you crack the throttle open.I have not checked the needle height yet or the size of the jets i was just wondering what the settings were so i had a clue where to start from.
Standard settings for the 05' Raga (sea level) are:
MAIN: 122
PILOT: 45 (48 OK)
NEEDLE: JJH (CENTER OF FIVE POSITIONS)
SLIDE: 3.5
AIRSCREW: 2.5 TURNS OUT
FLOAT HEIGHT: ARMS IN LEVEL PLANE WITH FLOAT BOWL BASE (PARALLEL)
Other riders have found a slight change to these settings help fine-tune the bike to their
riding area and skill level so you could do a TC search and get some additional data there.
Usually pinking on initial throttle opening can be cured with raising the needle and/or a slightly
richer pilot, then setting the air screw to get the best response when the throttle is quickly opened
from idle (there is no universal, "perfect" air/fuel screw setting and each engine is a little different).
Jon
