smallboy Posted August 15, 2010 Report Share Posted August 15, 2010 Hi is there listed any were how to change oil seals on this forum? Cheers David Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted August 15, 2010 Report Share Posted August 15, 2010 Which oil seals? Fork oil? Crank seals, clutch case o-ring, clutch side gasket, sprocket shaft? Quote Link to comment Share on other sites More sharing options...
gjbiker Posted August 15, 2010 Report Share Posted August 15, 2010 I'll hazard a guess at fork seals if it's anything to do with your other post? Not so sure about the Xispa forks as I've only ever seen one Xispa since they came out but there's a few vids on YooToob you could watch if you've never done a job like this before? Watchy Here Might be worth asking the Sherco guys? There was a rumour once that the Xispa was kind of like a Sherco GJ Quote Link to comment Share on other sites More sharing options...
smallboy Posted August 16, 2010 Author Report Share Posted August 16, 2010 Hi Sorry,the fork seals. Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted August 21, 2010 Report Share Posted August 21, 2010 They use the Marzzochi forks I think so follow a Gasgas guide. Quote Link to comment Share on other sites More sharing options...
