madalec Posted January 27, 2005 Report Share Posted January 27, 2005 Hi just wondering if anyone out there knows the model number/details of the rear wheel bearings for this Fantic? (White with Blue/Yellow tank) I am hoping to source the wheel bearings locally if possible! I also need other parts such as sprockets, but I am going to contact Bill Pye for those as he was able to supply them for my old 303 Fantic. The other issue I have is with the clutch, it doesn't seem to fully disengage (don't know if that's the correct term, but the wheel rotates when the clutch lever is fully against the handlebar) Someone suggested taking the clutch apart and cleaning burs? Does this sound correct? I am not a mechanic, but want to sort this out if I can, so any help/suggestions would be appreciated. Thanks Tony Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted January 27, 2005 Report Share Posted January 27, 2005 The bearing no.s will be on the old ones somewhere, if you can't see them just take the bearings in to a local stockist and get some there. They will probably be cheaper too. Quote Link to comment Share on other sites More sharing options...
grib Posted January 27, 2005 Report Share Posted January 27, 2005 If you can't read the numbers on the bearings measure them and check this; Bearing sizes. I find that my local bike shop is as cheap as local bearing suppliers. Make sure you get sealed bearings though (2RS suffix). Quote Link to comment Share on other sites More sharing options...
