pazaz Posted August 19, 2010 Report Share Posted August 19, 2010 There is a loud creaking noise coming from the back end of my Evo which is driving me mad!! I have greased all the suspension linkages and swinging arm bolt but this hasnt resolved the annoying problem. Anybody exerianced before this or anyone have any ideas what may be causing this? Such a simple problem but cannot get to the bottom of. Cheers! Quote Link to comment Share on other sites More sharing options...
jer Posted August 19, 2010 Report Share Posted August 19, 2010 Did you take off the shock and grease the bottom bearing on it? Not just where the bolt goes through the hole, but the actual bearing inside it. I had the same noise on my sherco and thats what it was. Quote Link to comment Share on other sites More sharing options...
pazaz Posted August 19, 2010 Author Report Share Posted August 19, 2010 Yes I done that. Thanks Quote Link to comment Share on other sites More sharing options...
2lls Posted August 19, 2010 Report Share Posted August 19, 2010 sounds like the main swing arm bearings are dry, have you taken the swing arm off and checked the bearings ? Quote Link to comment Share on other sites More sharing options...
pazaz Posted August 19, 2010 Author Report Share Posted August 19, 2010 Think I may have only took out and greased the bolt Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 19, 2010 Report Share Posted August 19, 2010 top shock bolt? Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted August 19, 2010 Report Share Posted August 19, 2010 Is it when you ride it or just when your sat on it or moving it... My scorpa creaks a bit, but it's just the rear brake pads in contact with the disc. Only does it when barely moving the bike around...ie. putting fuel in, or checking things over. Quote Link to comment Share on other sites More sharing options...
danishtrial Posted August 20, 2010 Report Share Posted August 20, 2010 Hi we had the same problem i here in DK. if you loosen the bolt for the swingarm it will probably disapear. !!! the cure is to take of the swing arm and with a file, thake a few tenth of a mm away, you will be able to see where the swingarm rubs and is too wide round the end where the bearing sits. It helped here. Quote Link to comment Share on other sites More sharing options...
ianwilson Posted August 21, 2010 Report Share Posted August 21, 2010 (edited) Hi had the same problem. Quickfix is to use copper grease between the swingarm and the bearing bushes on the swingarm pivot bearings and dont overtighten the swing arm spindle bolt.You will have to remove the swingarm to do this properly. It appears that the tollerances are a little tight between the frame and the swing arm causing the creaking sound. To prove if its this just slacken the swingarm pivot bolt nut off and it should go. Edited August 21, 2010 by ianwilson Quote Link to comment Share on other sites More sharing options...
elkay Posted August 22, 2010 Report Share Posted August 22, 2010 Check to make sure the muffler isn't rubbing the spring. I had the same annoying noise, pulled the entire rear linkage apart, only to discover the muffler was rubbing slightly. Quote Link to comment Share on other sites More sharing options...
pazaz Posted August 23, 2010 Author Report Share Posted August 23, 2010 Slackened the swinging arm bolt and as sugguested its gone. Cant fault you all for your help, cheers!! It was driving me nutz but its a pleaseure to ride again :-) Quote Link to comment Share on other sites More sharing options...
