arun1664 Posted January 27, 2005 Report Share Posted January 27, 2005 Hello I wonder if any of the good and the wise have any ideas? Towards the end of a trial last weekend the bike (92 Pinky) started to tickover erraticaly, almost as if it had an air leak. I have checked the thing over and apart from a dry foam air filter (now oiled) all looks well. Any thoughts gratefully received! As an afterthough, anybody know what I can stick the saddle back on with? Thanks, Mike Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted January 27, 2005 Report Share Posted January 27, 2005 (edited) Assuming you clean and re-oil your filter after each ride, if you do not, you run a high probability of dirt in the carb. Dismantle carb and fully clean out all jets etc. Sounds like you may have some dirt/debris in the pilot jet possibly. Edited January 27, 2005 by t-shock 250 Quote Link to comment Share on other sites More sharing options...
arun1664 Posted January 27, 2005 Author Report Share Posted January 27, 2005 Erm .... Assumtion re air filter cleaning is wrong, which probably explains, still on the bright side I have something to do tomorrow night now! Thanks for the help ... Mike Quote Link to comment Share on other sites More sharing options...
