keychange Posted August 25, 2010 Report Share Posted August 25, 2010 Hi I'm new to the forum and to TLRs I have acquired an 1982 TLR 200 that requires quite a bit of tidying up and replacement parts One thing I want to do away with is all the lighting and the battery. No problem removing all of it but I am concerned about what connections I have to jump in order to make it run without battery and not damage the CDI I am also on lookout for front and rear spokes. The gold rims are fine but spokes are very badly rusted. Cheers Andrew Dorrigo - Australia Quote Link to comment Share on other sites More sharing options...
totalshell Posted August 25, 2010 Report Share Posted August 25, 2010 just had some spokes made for me by http://www.central-wheel.co.uk/spokes/spokes.html sent them an old spoke and nipple and got the replacements back within 3 days. product was excellent. Quote Link to comment Share on other sites More sharing options...
hondanut Posted August 25, 2010 Report Share Posted August 25, 2010 just trace the wires for the lights ect back, and if you just disconect them it will be ok, the cdi does not require a battery to run, so about 1/2 hour should see it done. it is quite easy to do, unless someone has mucked about with it Quote Link to comment Share on other sites More sharing options...
keychange Posted August 26, 2010 Author Report Share Posted August 26, 2010 Thanks guys, both of you Quote Link to comment Share on other sites More sharing options...
