mcman56 Posted August 30, 2010 Report Share Posted August 30, 2010 I have been riding a 2002 2.9 for a while and am thinking about a newer, maybe 2005, 4rt. Can anyone provide a comparison? I believe I will like the 4 stroke power. I realize it is not the same but have a TLR200 and like the smoother slower revving type power. But...do you feel the extra 10 lbs? How do the suspensions compare? The 02 still has damper rod type forks and I can feel spikes at high trail speeds. Does the 4rt run Showa front and back? Does the 4 stroke efi make it a little harder starting. Is the high idle easy to get used to? Quote Link to comment Share on other sites More sharing options...
bobtlr Posted August 31, 2010 Report Share Posted August 31, 2010 hey, i had a 4rt for 2 years and they are good bikes but when changing back to a 2 stroke you feel the weight difference! they start good (not when in gear) the high idle speed takes some time to get used to but its not a problem showa front and rear and they are good, rear is a lot better than a sherco. best regards bob Quote Link to comment Share on other sites More sharing options...
cyclist Posted September 4, 2010 Report Share Posted September 4, 2010 I had a Sherco and didn't like the suspension. I think the 4RT suspension is much better. Took me a while to adjust to the 4 stroke. Very happy with mine, great bike. I will be at the Bear Valley PITS event on Sunday and you can ride mine if you want. Scott Quote Link to comment Share on other sites More sharing options...
