Replacement Of Oil Seal Adjacent To Front Chain Sprocket
howard
Yeah you can.
I'd recommend cleaning the shaft up really well before removing the seal, if necessary use some emery cloth to remove any rust.
Before putting the new seal on wrap the end of the shaft with insulation tape to prevent the seal snagging and smear some grease on the sealing surface of the seal.
