Txt 250 (03)
dcj1
that is strange, mine is a txt pro 2003 if that makes any difference. I assume yours is too, i think they changed the clutch case's on the 03's onwards perhaps you have the older type on yours.
But i'm not sure now, 400 is what i use and like i said it's 3/4 up the sight glass.
Sorry i couldn't of been more help, perhaps someone else on here will have a better idea
  • 2 weeks later...
The 2002 TXT PRO had a smaller gearbox with only 330 ml oil.
From 2003 the manual says 550ml but most use between 450 and 500 ml. Just check the sight glass.
Btw: Dont forget to let the oil run into the gearbox. The channels between clutch and gearbox are tiny, so it takes a while before it levels out.
-Jan
Edited by JanDyb
