dcj1 Posted September 11, 2010 Report Share Posted September 11, 2010 Hi Guys, as much as i try, i cannot find it, so i qm now asking you! how much oil do ineed in the gearbox. . . . . . something tells me it is 500mls is this correct? many thanks. Quote Link to comment Share on other sites More sharing options...
steve1979 Posted September 11, 2010 Report Share Posted September 11, 2010 400ml is the norm i think, thats what i put in mine and it fills it 3/4 of the way up to the top of the oil window Quote Link to comment Share on other sites More sharing options...
dcj1 Posted September 11, 2010 Author Report Share Posted September 11, 2010 Thanks Steve, i had already put 500mls in mine - but it is only just in view on the optic, thats what had me concerned. Quote Link to comment Share on other sites More sharing options...
steve1979 Posted September 12, 2010 Report Share Posted September 12, 2010 that is strange, mine is a txt pro 2003 if that makes any difference. I assume yours is too, i think they changed the clutch case's on the 03's onwards perhaps you have the older type on yours. But i'm not sure now, 400 is what i use and like i said it's 3/4 up the sight glass. Sorry i couldn't of been more help, perhaps someone else on here will have a better idea Quote Link to comment Share on other sites More sharing options...
jandyb Posted September 20, 2010 Report Share Posted September 20, 2010 (edited) The 2002 TXT PRO had a smaller gearbox with only 330 ml oil. From 2003 the manual says 550ml but most use between 450 and 500 ml. Just check the sight glass. Btw: Dont forget to let the oil run into the gearbox. The channels between clutch and gearbox are tiny, so it takes a while before it levels out. -Jan Edited September 20, 2010 by JanDyb Quote Link to comment Share on other sites More sharing options...
