Pgm-fi Setting Tool
clarkie
hi can anyone tell me if this tool is worth getting and if so how hard to use, also can it be used on any year of bike or do you have to match the year to the software if that makes sense ie can one that says 2005 be used on a 2008 bike
i read that it can diagnos if your bike has a problem
ps. i do have a programmable throttle many thanks
You need correct software to match either a single or 2 stage throttle body. Once sorted its very easy to change maps (using pre designed alternatives) and can help you tune bike to your riding style/ability.
Its also easy to alter an existing map but would suggest that unless you know what you are doing would be easy to make performance worse rather than better. Several good alternative maps are available on the intyweb.
Check previous threads for some links
