jamesgi11 Posted September 15, 2010 Report Share Posted September 15, 2010 Hi there very new to all this, so this might seem like a stupid question, but here goes! At the rear of the bike just by the rear swing arm there are 2 small "overflow" pipes. At a guess is one for fuel? What's the other one for? Thanks in advance Quote Link to comment Share on other sites More sharing options...
totalshell Posted September 15, 2010 Report Share Posted September 15, 2010 from earllier ( much much earlier) posts and with thanks to Billy T The first area of urban legend is the two little brass outlets with the pink hoses attached. You may know these as the Quote Link to comment Share on other sites More sharing options...
jamesgi11 Posted September 15, 2010 Author Report Share Posted September 15, 2010 K cool, so where is overflow for the rad? Quote Link to comment Share on other sites More sharing options...
graeme17 Posted September 15, 2010 Report Share Posted September 15, 2010 K cool, so where is overflow for the rad? On the radiator filler, near the cap. Quote Link to comment Share on other sites More sharing options...
jamesgi11 Posted September 15, 2010 Author Report Share Posted September 15, 2010 K now I'm confused. My problem at the minute is that I can't fill the rad up. So I've popped the plastic cover out of the frame and cap off. Then when I poor the water in it is running straight out of one the little pipes by my the swing arm. Any ideas?!? Quote Link to comment Share on other sites More sharing options...
chris morris Posted September 15, 2010 Report Share Posted September 15, 2010 Firstly the two pipes by your swingarm are gearbox breather and flywheel breather. Your problem could be your water pump seal has gone or inner clutch cover has corroded and as soon as you put the water in the radiator it's coming striaght back out of the gearbox breather, what is your gearbox oil like? milky? Quote Link to comment Share on other sites More sharing options...
jamesgi11 Posted September 15, 2010 Author Report Share Posted September 15, 2010 Many thanks for the reply Chris, that makes a bit more sense to my simple mind now. The first time I tryed to fill the rad i did end with a milky pubble from the tube. Where/how do I go about checking the oil? Regards Quote Link to comment Share on other sites More sharing options...
totalshell Posted September 15, 2010 Report Share Posted September 15, 2010 i suppose we need to know a couple of things, how old is your beta and how long have you had it?. i'd drain the oil into a clean tin/ pan/jar/ vase and check it out.. nice and clean and oily ( even black as long as it has no bits in it) is ok and you can either refill with new or put the old stuff back in. assuming the oil was ok try to refill the rad again this time slowly pour the water in and check to see if the water level is rising and water is going down the overflow tube ( i think though that some if not all rev3 have the overflow on top of the cap) if water is coming from elsewhere ie the pipe by the rear wheel it must be coming from the gearbox and sadly your water pump need checking out.. search this site thier are plenty of rewferences to water pumps on rev3's Quote Link to comment Share on other sites More sharing options...
jamesgi11 Posted September 15, 2010 Author Report Share Posted September 15, 2010 It's a 2003 or 2004 I've had since early this year. Just been out and checked the oil and it's milky. So I take I need to look into my water pump? Quote Link to comment Share on other sites More sharing options...
totalshell Posted September 15, 2010 Report Share Posted September 15, 2010 yeh drain the oil and water and take the water pump off the side of the engine. dont order any bits till you know for sertain what you nedd and what the pump looks like inside Quote Link to comment Share on other sites More sharing options...
totalshell Posted September 15, 2010 Report Share Posted September 15, 2010 hope yours looks better than this.. http://www.trialscentral.com/forums/index....rt=#entry108226 search under water pump in the beat forum for more info Quote Link to comment Share on other sites More sharing options...
