B40 Gearbox Probs
martyd
Hi Guys
Bsa B40 with wd ratios
Sometimes will ,but mostly not select 4th
Then will not select 3rd
Gearchange is a bit wooly
New plungers on the gearshaft new bearings etc
Tried differnt quadrants
Anyone no where to look next?
Marty D
I had a similar problem once with a B25 g/box. I had somehow assembled the box such that the output shaft was shimmed too far towards the clutch and I could only engage gears 1,2, and 3. Check the primary chain alignment i.e. clutch teeth aligned with the engine sprocket, if the clutch is too far out then this may be the problem, otherwise hopefully someone else has a better suggestion, good luck.
