Gas Gas Txt 280 Going In Reverse?
peasie
I found it hard to believe that a FW running engine can suddenly turn backwards due to a faulty iginition or flywheel. That should mean that the engine running at idle first stops and start again turning backward.... what kind a force can accomplish this? It is more likely to stall then if the iginitions fools up.
What maybe happens is that after coming to halt on a slope (after running) that the clutch is not pulled in completely, then then engine stalls, bike rolls back on the slope and start to turn backwards.
