yamty Posted September 19, 2010 Report Share Posted September 19, 2010 Hello The previous tire on my Ty 250 mono had a buckle in it, and yesterday i put a new tire on to find it still has a buckle. it is at the rim lock where the tire isn't seated properly. Does anyone know how to sort this? Cheers Lewis Quote Link to comment Share on other sites More sharing options...
tt5th Posted September 19, 2010 Report Share Posted September 19, 2010 Is the rim straight? Can be a bit tricky getting it seated properly over the rim lock, just keep trying till you get it right. I put a nut right on the end of the rim lock to stop it vanishing back inside the rim and then push it as far in as the nut allows to get the edges of the tyre right down either side of it. Quote Link to comment Share on other sites More sharing options...
mattylad Posted September 21, 2010 Report Share Posted September 21, 2010 Are you trying to fit a tubeless tyre to a tubed rim? If that is the case you will get the same symptoms as you describe. If not use water to lube the bead and inflate to 50-60 psi to push out. Quote Link to comment Share on other sites More sharing options...
yamty Posted September 21, 2010 Author Report Share Posted September 21, 2010 Hi Yes it is a tubeless tire that i am using with a tube so that is maybe the problem. Cheers Lewis Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted September 21, 2010 Report Share Posted September 21, 2010 HiYes it is a tubeless tire that i am using with a tube so that is maybe the problem. Cheers Lewis I'm not having a dig here honest but why do people keep trying to fit tubless tyres on tubed rims? I really dont understand especially as the problems have been discussed at length on here. Why not just fit a tubed tyre to a tubed rim and a tubeless tyre to a tubeless rim ? Honestly not having a dig at you i just dont get it Quote Link to comment Share on other sites More sharing options...
yamty Posted September 21, 2010 Author Report Share Posted September 21, 2010 Hi The Tyre was used and given to me by a freind as it is in better contition than the one that was on origionaly, so i thought i would give it a go. Lewis Quote Link to comment Share on other sites More sharing options...
